Show ARP Table Information
Show ARP information to view the configuration information in the ARP table.
When you use the interface parameter with the show ip arp command,you can display ARP configuration information only for a specific switch.
The show ip arp command displays all configured and dynamically learned ARP entries in the ARP table.
  1. Enter Privileged EXEC mode:
    enable
  2. Display the ARP table:
    show ip arp [<A.B.C.D>] [-s <A.B.C.D>] [gigabitEthernet <slot/port[/sub-port]>] [interface <gigabitethernet|vlan>] [nlb] [spbm-tunnel-as-mac][vlan <1-4059>] [vrf WORD<1-16>] [vrfids WORD<0-512>]
Switch:1#show ip arp
                                  IP Arp - GlobalRouter
IP_ADDRESS      MAC_ADDRESS        VLAN  PORT                 TYPE    TTL(10 Sec) TUNNEL
192.0.2.1    00:09:0f:09:00:08  20    1/3                  DYNAMIC 2159
192.0.2.12   b4:a9:5a:ff:f8:40  20    1/3                  DYNAMIC 458
192.0.2.25   e4:5d:52:3c:65:00  20    -                    LOCAL   2160
192.0.2.154  d4:ea:0e:c2:08:00  20    1/3                  DYNAMIC 2131
192.0.2.157  00:1c:17:b1:ec:80  20    1/3                  DYNAMIC 2131
192.0.2.161  fc:a8:41:fb:40:00  20    1/3                  DYNAMIC 2131
192.0.2.253  e0:db:55:d4:e5:7c  20    1/3                  DYNAMIC 2041
192.0.2.255  ff:ff:ff:ff:ff:ff  20    -                    LOCAL   2160
                           IP Arp Extn - GlobalRouter
MULTICAST-MAC-FLOODING    AGING(Minutes)       ARP-THRESHOLD
disable                   360                  500
c: customer vid   u: untagged-traffic
8 out of 8 ARP entries displayed
ARPs on TX-NNI: Current = 0, re-ARP count = 0
Variable definitions
Use the data in the following table to help you use the show ip arp command.
Variable
Value
-s
Specifies the subnet for the table.
gigabitEthernet
Displays the entries for a particular brouter port.
interface
Displays ARP interface configuration information.
Use the following parameters to display ARP table information specifically for:
  • gigabitethernet {sub-port]][,...][slot/all][all]} displays IP ARP gigabitethernet interface information
  • VLAN <1-4059> displays IP ARP VLAN interface information
Example: show ip arp interface vlan 1
nlb
Displays the Network Load Balancing (NLB) ARP entries on the switch.
spbm-tunnel-as-mac
Displays the remote host name in the TUNNEL column for the SPBM ARP entry.
vlan
Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.
Use these parameters to display ARP table information specifically for:
  • vrf WORD<1–16>—the VLAN VRF name in a range from 1 to 16 characters
  • vrfids WORD<0–512>—the VLAN VRF ID in a range from 0 to 512
Example: show ip arp vlan 1 vrf 1
vrf WORD <1-16>
Specifies the name of the VRF.
The total number of ARPs listed in the summary line of the "show ip arp" display represents the total number of ARPs on the chassis including all VRFs.
vrfids WORD <0-512>
Specifies the VRF ID.
<A.B.C.D>
Specifies the network IP address for the table.
Use the data in the following table to help you understand the output of the show ip arp command.
Parameter
Description
IP_ADDRESS
Indicates the IP address where ARP is configured.
MAC_ADDRESS
Indicates the MAC address where ARP is configured.
Indicates the VLAN address where ARP is configured.
PORT
Indicates the port where ARP is configured.
TYPE
Indicates the type of learning (dynamic or local) where ARP is configured.
TTL<10 secs>
Indicates the time to live as tenths of a second where ARP is configured.
TUNNEL
Displays whether IP ARP multicast MAC flooding is enabled or disabled. When enabled, the ARP entries for multicast MAC addresses are associated with the VLAN or port interface on which they were learned.
AGING (Minutes)
Displays when the ARP aging timer expires.
ARP-THRESHOLD
Displays the maximum number of outstanding ARP requests that a device can generate.
